this update should (hopefully) fix the issue with zeroing of the temp/dew gauge upon each update.
Instructions for update:
- replace all the files
- go to your settings and set up the temperature gauge limits. To make this work you now have to select a value from a select box, your original settings for this particular parameter will be reset by the update so make sure you do this. Other settings of the gauges will of course remain and you don´t need to set it up again.
Enjoy
Gracias Jachym. Error corregido con esta nueva versión y siguiendo tus indicaciones.
Saludos.
