this is a compatibility fix. The plugin needed update to be compatible with the new v11 menu (fixing sunrise/sunset times).
Update process:
If you are just updating this plugin, first find the index you were using, rename it again to index and replace your original one. Also replace the liveGaugesWCVersion.txt. Other files do not need updating.
Enjoy
Take a look @ this here http://weather.hoke.org/meteo/plugins/liveGaugesWC/
I’ve actually deleted and reinstalled the plugin as the sunrise/set was still not displaying right after doing the update as described above
Also on the left hand side, the D M Y seems to break odd … may be my font selection, but the “Y” line breaks into the thermometer
-jph
