6 thoughts on “Block Update – Steel Series Gauges 2.1
    • Whenever you update a block/plugin, you must replace ALL files, including all subfolders. Your settings is saved in settings.php, which is not part of the block/plugin download files so you dont have to worry about your settings being overwritten/lost.
      In this case I suspect you did not update the files inside scripts folder of that block.
Leave a Comment
