Plugin/Block Update – Steel Series 2.0
surprise, surprise 😀
The updated version now supports the new API – this means also the SteelSeries Gauges block will use the API since the block uses the settings file from this plugin.
Updating this plugin and choosing API means both the plugin and the block will use it. You do not need to make any changes to the ssGauges Block.
Enjoy
6 thoughts on “Plugin/Block Update – Steel Series 2.0
  1. I have been waiting so long for this plugin to show in real-time! Thanks to the new api I’ve now got 3-second wind updates in Meteotemplate!
    For a very long time I had set the pressure range from 1005 – 1020 (yes, that is the pressure range in Suriname!), but I noticed the plugin would not accept lower values higher than 1000 hPa.
    Jachym, you would do me a big favour when I could change the black colored background into something light.
    Cheers, Luc
Leave a Comment
