in this new version I extended the highlight feature.
Originally, everytime the script triggered update, the timestamp flashed. Now the timestamp will only flash if that update loaded new values. So if the block update interval is shorter and the same conditions are loaded again during update, the timestamp will not flash.
Second, now also the actual numbers (parameters) will flash – but only those that changed since last update.
So basically the flashing is now extended to the parameters as well, not just timestamp and the flash only occurs if the value changed.
In addition I also improved handling of decimal places:
Example:
Previously: 18.8, 18.9, 19, 19.1
Now: 18.8, 18.9, 19.0, 19.1
Enjoy
Hi Jachym,
Very nice feature!
But… In my colour settings the updates are hardly visible, even when the update time is set to 1.5 s. Maybe change the background colour too during the flash?
Cheers, Luc
Hi Luc,
I dont think changing the bg is a good idea, it would be too distracting. But you can change the color in the script, I am sure you will find it. The problem is that it is hard to find a color that will work for everyone because I dont know which color each one of you chose for the template
Luc,
I set it to 3 sec – and I am very happy with this setting!
Jachym,
one of the best blocks! 😉
This is a very useful improvement – loving it!
