this update implements some timing adjustments to make sure you always have the most recent data. If you are updating this plugin just replace update/update.php and you do not need to change any settings or CRON job.
Enjoy
www.meteotemplate.com
Enjoy
few problem
(The live conditions file was not found. Make sure you have the NetAtmo plugin installed and using at least version 2.0)
http://thenioux.gedfr.eu/template/indexDesktop.php
Brilliant. Works absolutley perfect.
Don’t forget to upload the NetAtmoVersion file to show the right version in the administration control panel
Thank you for an exellent work 🙂
