new version of Meteotemplate is now available – Meteotemplate 17.1 Nectarine. It is not a major update but it does include some bug fixes, one major optimization step in the database update (should decrease the server load a lot) and one CRITICAL security update, so I recommend everyone to update! There is also a few improved scripts, such as better SEO or FB sharing optimization.
Update process
As I promised, the update process will be semi-automatic, just like last time. This means you will have to download the update file manually, upload it via FTP, but the actual update will then be performed automatically by a single script. Make sure you follow the instructions below closely.
Please use the new token request page and do not email me directly. The process of token issuing is now also semi-automated (issuing hundreds of tokens last time took many hours and this will make it a lot simpler for me). If you just email me I will not be able to generate the token easily. In addition please include everything that you are asked to specify on the token request page and have a look and agree with the license (nothing new, just a summary from the original license in the wiki, highlighting the major points, but please read it because after some incidents in the past I will not issue tokens to users who do not respect it).
as always, you will need a download token for the update. To get one, go to the Downloads page and click Get Token. I will try to issue tokens within 24 hours maximum. I might send a few at the beginning and then wait just to make sure that if there is some major problem it affects as few people as possible.
extract the package and inside you will find a folder update_17.1
use an FTP client to transfer update_17.1 into your update folder in the template
go to your website and login as admin
now you will do the actual update by opening the following page (making sure the update_17.1 folder is in the update folder):….templateRoot/update/update_17.1/updateTemplate.php
this script will first check several things (make sure it is placed in correct location, make sure you are using version 17 and check you are logged in as admin). It will then automatically create a v17Backup folder in your backup folder and backup all the necessary files which will be changed.
If the backup and checking process goes ok it will update and add all the new files from version 17.1 automatically and inform you about any potential problems during the update and what to do next.
Please make sure you read the entire page, at the end of the update page will be summary information about any potential files that were not updated (in which case you will need to transfer them via FTP as usual) and what to do next.
Enjoy
29 thoughts on “Meteotemplate 17.1”
Updated without any problem. Thanks!
Seamless update to 17.1! Thanks!
Always are ok after update
Thanks a lot
As Always update went smoothly and flawlessly. No issues at all.
Another smooth update and a surprise fix as I got my first ever “station offline” email alert which I could never get to work before this patch. Very nice!
Bonsoir et bravo mais je n’est toujours pas reçu mon code
Good evening and congratulations but I still have not received my code
Bonjour Michel
Refait une demande à Jachym , pour moi il était dans ses spams
bonne journée
As usual really quick to update and all done with no problems
Update successfull 😉 Thank you
Thank you for the good job Jachym
Another smooth update.
Great job Jachym, thanks again !
perfect work, as usual.
Thank you, Jachym
Thanks..
It works good.
Perfect (as usual)
Thnak you for your great job. Now going to the donation button.
Joachim
smooth as allways this update.
I hade the same experience with bio-index plugin (although not related to this update). I manually downloaded version 3.3 from this website but found that the version.txt inside the zip still has 3.2. So that might be a little mistake Jachym?
Today I installed the update “Meteotemplate 17.1 Nectarine”.
The process has been instantaneous and everything works perfectly :-))
There is only one small problem, which was already happening before the update; the “bioindexes” plugin is not updated manually or automatically.
Thank you very much for everything Jachym
Javier
Seamless, easy update. Thanks Jachym!
Super
Cela fonctionne
Mille mercis
Great job on the update. I hope your job is going well and life is wonderful.
In my case, updated successfully. Thank you.
Very Well!!
Parfait en deux minutes tout installé.
encore merci Jachym
Cheers Jachym
All updated without any problems.
Donation sent.
Great job. it works very well!
Thank You.
Work perfectly.
Thank you Jachym, Great Job.
Quick to receive token. Fast and painless update. Instructions are spot on. Thanks
Same here: Quick token & download, followed the server (NAS) upload instructions, and saved the main settings. – All works at its best 😉
Thanks again Jachym,
Cheers, Christian
token received in less then 15 mins, dowloaded the “update” in 2 seconds, uploaded in 10 seconds, went to the update page and then (as written on the update page down the page, go to main settings and save your config)
Thanks a lot
Bonjour Michel
bonne journée
Thank you, Jachym
Thanks..
It works good.
Perfect (as usual)
Joachim
Javier
Super
Cela fonctionne
Mille mercis
Very Well!!
encore merci Jachym
Cheers Jachym
Donation sent.
Thank You.
Work perfectly.
Cheers, Christian
All done zzzzzzzz 😉
