new version of Meteotemplate is now available – Meteotemplate 17.2 Nectarine. It is not a major update but it does include a new feature, a critical update fix for all WU users and a bug fix.
Update process
As I promised, the update process will be semi-automatic, just like last time. This means you will have to download the update file manually, upload it via FTP, but the actual update will then be performed automatically by a single script. Make sure you follow the instructions below closely.
Please use the new token request page and do not email me directly. The process of token issuing is now also semi-automated (issuing hundreds of tokens last time took many hours and this will make it a lot simpler for me). If you just email me I will not be able to generate the token easily. In addition please include everything that you are asked to specify on the token request page and have a look and agree with the license (nothing new, just a summary from the original license in the wiki, highlighting the major points, but please read it because after some incidents in the past I will not issue tokens to users who do not respect it).
as always, you will need a download token for the update. To get one, go to the Downloads page and click Get Token. I will try to issue tokens within 24 hours maximum. I might send a few at the beginning and then wait just to make sure that if there is some major problem it affects as few people as possible.
extract the package and inside you will find a folder update_17.2
use an FTP client to transfer update_17.2 into your update folder in the template
go to your website and login as admin
now you will do the actual update by opening the following page (making sure the update_17.2 folder is in the update folder):….templateRoot/update/update_17.2/updateTemplate.php
this script will first check several things (make sure it is placed in correct location, make sure you are using version 17.1 and check you are logged in as admin). It will then automatically create a v17_1Backup folder in your backup folder and backup all the necessary files which will be changed.
If the backup and checking process goes ok it will update and add all the new files from version 17.1 automatically and inform you about any potential problems during the update and what to do next.
Please make sure you read the entire page, at the end of the update page will be summary information about any potential files that were not updated (in which case you will need to transfer them via FTP as usual) and what to do next.
What is new
NEW – in the Main setup you can now enable a cookie consent (in accordance with the GDPR rules in Europe)
UPDATE – the WU updates should now work again, using the latest API format WU provides. Please note that you will need to specify your WU API key in the Main setup (there is a new input box for it)
FIX – several minor bug fixes
Enjoy
22 thoughts on “Meteotemplate 17.2”
Is this project down?
It would be nice to know, so that we can move along and try alternatives.
Thanks,
no, it definitely isn´t dead 🙂
Updated with no problems! Thank you!
After update not able to connect to the Wundergrorund database. My station appears offline.
Working out I needed to put the WU and API KEY data on the main configuration page, as indicated in the instructions. Sorry.
After updating, I get the feeling that it is not able to connect to the Wundergrorund database. My station appears offline.
Hi, Jáchyme
Update 17.1 -> 17.2 carried out without any problems.
Many thanks for your great work.
like every update before: no problems! thanx Jachym
Fantastic how you manage to make it so easy for us, to update this new version.
Thank you so much for all your hard work and for all these new improvements.
Updated without any problem. Thanks!
Absolutley perfect!
Update runs very smooth and fast.
The update worked good. Thanks.
Update not working for me. Keeps saying “Unauthorized access”. Any ideas.
I got it now. Forgot to login into admin first.
Thanks Jachym
The upgrade work perfectly for me.
Great job Jachym.
Hi Jachym
17.2 update carried out without any problems.
The update works good Jachym
once again, update went smoothly.
Mise à jour effectué. Parfait
Merci Jachym
Bonjour,
Mise à jour ok mais je ne trouve pas dans la configuration principale, la case pour activer l’autorisation d’utilisation d’un cookie (conformément aux règles GDPR en Europe).
Amicalement didier
Section Additional Security
Show cookie consent Yes/No
As usual really quick to update and all done with no problems. 👍😃
Thanks,
Hi, Jáchyme
Absolutley perfect!
Thanks Jachym
Great job Jachym.
Hi Jachym
Merci Jachym
Bonjour,
Amicalement didier
