Based on your feedback I slightly modified the Density Altitude block. Instead of the difference between real elevation and density altitude it now gives the absolute value. This means you also have to specify station elevation in the block settings.
The station elevation is now also displayed in the block.
Bug fix for incorrect icon viewed when using the light theme.
