Block Update – Interactive Graph 3.0
based on a suggestion from one of you I updated the interactiveGraph block. In the new version, you can now set the colors of the individual graphs. Just be careful and make sure if you change the “default” that the color you choose is nicely visible using the theme you chose for your homepage.
Update process:
Simply replace all the files and then follow the instructions in the block settings.
Enjoy
1 thought on “Block Update – Interactive Graph 3.0
Leave a Comment
