as part of the process of checking functionality and adding new features to blocks I updated two blocks:
Cloud Height 2.0
In the new version you see not just the cloud height above the ground, but also the same value converted to sea level. However, make sure you have your station elevation filled in the setup file and also the units (m or ft).
CO2 2.0
In the new version I added percentage changes and also an expandable section which shows table of past values.
The update process is very simple. In both cases just delete the entire block folder and replace it with this one. No settings for these blocks.
Enjoy
Excellent. Thank you.
