updated meteogram block
Re: updated meteogram block
Post by alexvanuxem » Thu Mar 03, 2022 6:42 pm
the site is asking me to update to the meteogram to 4.0. But this is less pleasing actually, reverted back to 3.3c.
In 4.0 there are now settings anymore....
fyi
atari
Station model: ws2315
Software: weewx,cumulus
Post by atari » Wed Mar 09, 2022 1:10 am
I have ver 3.1 but stop working, i try to update & change config but still not geting any data
Post by davidefa » Wed Mar 09, 2022 7:32 am
Did you try ver 3.4 ( ver 4.0 seems not working correctly )?
atari
Post by atari » Wed Mar 09, 2022 9:36 am
yes i try, meybe not working for meteotemplate 16 not sure
Post by davidefa » Wed Mar 09, 2022 11:02 am
As you say, compatibility is not ( I mistakenly wrote 'now' ) guaranteed. I Think you should update to meteotemplate 18.0 first ( make a backup of all your site and all your database first )
hcorrin
Station model: Davis VP2
Post by hcorrin » Fri Mar 18, 2022 11:00 pm
i just discovered version 4 tonight but when i updated all i got was a blank block and as has been noted no settings in block setup so have reverted back to 3.4 i am using meteotemplate 18.0
tobydude
Software: Weatherdiaplay
Post by tobydude » Sat Mar 19, 2022 4:26 am
hcorrin,
Have you tried this version? Version with colors.
meteogram_3.3d1.zip
(756.32 KiB) Downloaded 947 times
amonphi
Station model: Ecowitt GW1003
Post by amonphi » Sun Jun 12, 2022 3:47 pm
riteoh wrote: Thu Mar 03, 2022 3:41 am I've just noticed that there was an update to V 4.0 of this block. Once updated, the new version seems to have white see though panels on both sides of the graph (refer image link below).
Has anybody else experienced this?
https://ibb.co/mvG9R90
updating from the V3.4 to the V4.0, I also confirm that I have white panels on the sides of the graphic designer.
I am back to the previous version until it is not resolved.
WessexWeather
Post by WessexWeather » Wed Jun 15, 2022 4:53 pm
Just to let you all know that the latest version 4.0 of meteogram doesn't work properly. Reverting back to my previous version 3.3 higher up this thread works fine. My advice would be NOT to use the automatic block updater with this particular block.
Simon (WessexWeather)
amonphi
Post by amonphi » Fri Jun 17, 2022 4:52 pm
WessexWeather wrote: Wed Jun 15, 2022 4:53 pm Just to let you all know that the latest version 4.0 of meteogram doesn't work properly. Reverting back to my previous version 3.3 higher up this thread works fine. My advice would be NOT to use the automatic block updater with this particular block.
ok thanks for the clarification
riteoh
Post by riteoh » Thu Jan 26, 2023 4:06 am
Have just installed the new mods block, and updated to v4.0 - but getting those white panels on the side, so have now reverted back to 3.3 and cleared cache.
Have checked settings and updated for my location (Wantirna, lat=-37.84989&lon=145.23763&altitude=91)
I'm now getting a Failed Loading Data error.
Am I using the incorrect version?
Post by davidefa » Thu Jan 26, 2023 9:24 pm
Last block version is 3.6 ( with only minor modifications, removed global options in highcharts which may conflict with other charts )
I tested your settings in ver 3.3d1 and following and it seems to work ok.
Could you post a link to your site so I can take a look?
meteogram_3.6.zip
(720.38 KiB) Downloaded 974 times
riteoh
Post by riteoh » Thu Jan 26, 2023 10:22 pm
Thanks David.
Now I'm not sure where I was getting V4.0 from as it isn't showing.. possibly looking at another block.
Have installed V 3.6, gone into Unofficial Block setup.. previous details were already there, but have updated again and saved the block. Same error.
Have cleared the cache from Block setup.. no change.
Page is www.eyesontheweather.com.au.
If admin access would assist you, then let me now, and I will PM the details.
Thanks again.
MeteoElMasnou
Post by MeteoElMasnou » Fri Jan 27, 2023 5:25 pm
davidefa wrote: Thu Jan 26, 2023 9:24 pm Last block version is 3.6 ( with only minor modifications, removed global options in highcharts which may conflict with other charts )
Thanks David, it works perfectly
Post by davidefa » Sat Jan 28, 2023 12:02 am
@riteoh
Yes, need access to your server file system, if you have installed the 'ultimate mod' the meteotemplate admin password is ok, if not I need an ftp access
riteoh
Post by riteoh » Mon Jan 30, 2023 1:33 am
@davidefa.
PM sent with the info you need.
Thanks.
Post by davidefa » Mon Dec 09, 2024 5:52 pm
ver 3.7
- updated block as tooltip didn't work anymore
meteogram_3.7a.zip
(760.64 KiB) Downloaded 653 times
Post by alexvanuxem » Tue Dec 10, 2024 4:36 pm
grazie mille!!!
steph
Post by steph » Mon Dec 16, 2024 3:24 pm
Works perfectly.
Thank you very much
