steelSeries plugin error: MIME type mismatch (X-Content-Type-Options: nosniff)
Posted: Sun Jul 18, 2021 10:13 pm
On my new server this plugin shows no gauge ( while the browser error console return this error )
This mod fixes it.
Re: steelSeries plugin error: MIME type mismatch (X-Content-Type-Options: nosniff)
Posted: Sat Nov 13, 2021 1:16 pm
by leonrossouw
Thank you...installed the mod...no luck yet.
Link :
http://cannonrocksweather.com/template/indexDesktop.php
Leon
Posted: Sat Nov 13, 2021 6:00 pm
Sorry, forgot to mention that you have to install this block mod to fix the same issue with the ssGauges block.
( by the way I see your
steelSeries plugin is working correctly )
Posted: Sun Nov 14, 2021 6:24 am
by leonrossouw
I have to really thank you...all good now after installing your plugin mod and blockmod
Leon.
Posted: Sat Feb 05, 2022 12:29 am
by alexvanuxem
Thank you,
I was busted my ass for hours on this one,
next time check the forum firts..
Posted: Mon Jul 18, 2022 9:12 pm
v4.1 ( Jul 18, 2022 )
- fixed php 8.0 compatibility issue ( in case selected time format is am/pm )
Posted: Tue Jul 26, 2022 6:52 pm
by Dehatter
Any thoughts on what is making the block fail?
Www.MeckWeather.com
Posted: Wed Jul 27, 2022 10:11 pm
I'm working on it... ( I need to setup a fully working test site with php 8.1 on my pc as I'm unable to find a free online hosting provider )
Posted: Sat Jul 30, 2022 4:38 pm
Ok, this should correct a bug that breaks compatibility with php 8.0/8.1 of block ssGauges
Posted: Thu Aug 04, 2022 4:57 pm
by Dehatter
Works perfectly!!
Thank you so very very much. I love my gauges...lol.
Posted: Tue Aug 09, 2022 6:13 am
by leonrossouw
I have noticed that the resolution of steelseries gauges is rather poor...it seems better on google chrome browser than for instance safari...see attached example screen shot (both on 4k monitor)
- Safari
- safari.png (348.93 KiB) Viewed 17336 times
- Chrome
- chrome.png (359.12 KiB) Viewed 17336 times
Is there a way to improve this ?
Leon Rossouw.
Posted: Tue Aug 09, 2022 9:01 pm
I'd say it could be a 'browser effect' ( but I'm not sure and I can't reproduce having no safari at hand ).
Verify if the 'image looks good' at 100% zoom and get worse zooming in, it could be the effect of some antialiasing/optimization/speedup setting of the browser.
Posted: Sat Oct 08, 2022 9:03 am
by bribon
Hello!
I have another problem... when entering the plugin I get this error: parsererror: SyntaxError: Unterminated string in JSON at position 1126
What can be the file that gives me this error? I can't find a solution... Thanks!
http://astrometeopinedas.es/plugins/ste ... /index.php
Posted: Mon Oct 10, 2022 3:04 am
by andyk1
What ver of Steelseries and whar api version.
Posted: Mon Oct 10, 2022 1:53 pm
@bribon
I think it is due to the fact that you have no UV/solar sensor.
This mod should fix it ( extract it in the plugins/steelSeries directory ).
Posted: Thu Oct 13, 2022 5:51 am
by bribon
Fixed up! Thank you very much!!
