New Block – Tides & Currents U.S.
I created a new block with information about current water levels, water temperature etc. for various stations in the U.S., provided by the NOAA.
In the setting you specify which station to use, units and cache time. The block also includes description of the abbreviations. For the current conditions you will see the difference between the particular datum and current conditions, in the “more” section are the actual levels for the datums and at the top you will see current air and water temperature.
Thanks to Alex for the suggestion and info about the API!
DEMO
Enjoy
Leave a Comment
