New Block – Wind
New Block – Wind
some of you asked for something to show recent wind direction and how it is changing. So I created a “wind” block.
Based on your responses in the questionnaire, it is quite clear that if there is one thing you all suggested (or can be deduced from your suggestions) it is customization. I will therefore try to give you more options to customize things via the GUI.
In this block you can specify the intervals for which you want to calculate this (in hour steps, i.e. last 1h, 3h, 12h, etc.). The block will then show you the prevailing wind direction, wind speed (avg/max) and wind gust (avg/max). In the collapsable section there are also graphs, which you can customize in the block settings.
DEMO
Enjoy
1 thought on “New Block – Wind
Leave a Reply to Tamir engel Cancel reply
