3 thoughts on “New Plugin – Solar Power
  1. Hi Jachym
    I’m very interested in this calculation. In your Demo, I can see the actual value of 375 W/m2, this gives (x24) 9kW/day. Is the efficiency factor of 25% enough to take in consideration the night without sun? Could it be thinkable to take the 5-min-values of solar sensor measurements to have a more accurate count throughout the day?
    Thank you for your work!
    Martin
    • Hi Martin,
      this is just an example, it does not look at your solar values at all, it is only meant as a calculator. That 375 is just a default for everyone and whatever you insert there would be converted and you can then use it for the subsequent calculations. But it does not use anything from your actual values.
