New Block – RSS feed reader
a new block is now available. It is called “RSS feed” – the purpose of it is quite obvious.
In this block you can specify as many RSS feeds as you like and it will display them (assuming they confirm to the proper RSS format). Additionally, the items are automatically sliced into pages and you can specify the maximum number of items per page and you can also limit the length of the text for one item, which means if it is longer, it will be truncated at the nearest word, but making sure any HTML tags are preserved. Also supports pictures.
I hope most of the RSS will work, obviously I was not able to test every single RSS feed there is and I did find a few which did not work, however, those that did not simply did not work because they were not properly formatted as an RSS feed.
Download/screenshots: http://www.meteotemplate.com/web/blocks.php
2 thoughts on “New Block – RSS feed reader
  1. I’m very happy to discover this website. I wanted to thank you for
    ones time for this particularly wonderful read!! I definitely enjoyed every part of it and i also have
    you bookmarked to check out new things in your blog.
Leave a Reply to Bianco57 Cancel reply
