The ultimate mod
spd2612
Software: Meteobridge Pro 2
Re: The ultimate mod
Post by spd2612 » Sun Feb 05, 2023 7:05 pm
@davidefa
If I try to install a mod I get the pop up and it has
Failed to extract mod ZIP file
can I resolve this ?
Apache2 server, mysql Ver 8.0.32-0ubuntu0.22.04.2 for Linux on x86_64 ((Ubuntu))
I also do not have my WEB server setup to file owner as www-data that is only the group
Davis Pro 2
Meteobridge Pro2
GW 2000
WH57 Lightning Detector
Post by davidefa » Sun Feb 05, 2023 8:20 pm
There are different things that could go wrong.
Need to add a debug/verbose option to more easily pinpoint the problem.
Which mod are you trying to install?
spd2612
Post by spd2612 » Sun Feb 05, 2023 8:37 pm
It does not matter I get that error from all of them
I checked I have zip enabled on php
This just shows up in the white pop up window
Davis Pro 2
Meteobridge Pro2
GW 2000
spd2612
Post by spd2612 » Mon Feb 06, 2023 3:46 pm
ok it looks like its a permission issue I just dont know where ?
Warning: Undefined array key "id" in /var/www/hurricanepub/template/admin/modUpdateUnofficial.php on line 19
Warning: Undefined array key "ip" in /var/www/hurricanepub/template/admin/modUpdateUnofficial.php on line 20
Deprecated: explode(): Passing null to parameter #2 ($string) of type string is deprecated in /var/www/hurricanepub/template/admin/modUpdateUnofficial.php on line 22
Warning: Undefined array key 1 in /var/www/hurricanepub/template/admin/modUpdateUnofficial.php on line 24
Warning: mkdir(): Permission denied in /var/www/hurricanepub/template/admin/modUpdateUnofficial.php on line 32
Warning: file_put_contents(modTemporary/.zip): Failed to open stream: No such file or directory in /var/www/hurricanepub/template/admin/modUpdateUnofficial.php on line 43
Davis Pro 2
Meteobridge Pro2
GW 2000
