Many bad user records in Usermap.txt for UserMap block
beaumariswx
Software: CumulusMX
Re: Many bad user records in Usermap.txt for UserMap block
Post by beaumariswx » Sat May 27, 2023 2:52 am
Hi Jachym,
Is there any chance of adding my site to the user.txt
I have manually updated my local copy for now.
https://beaumaris-weather.com/meteobeau ... /index.php
        "lat": "-41.428611",
        "lon": "148.272500",
        "url": "http://beaumaris-weather.com/meteobeaumaris",
        "alt": null,
        "name": "Tony",
        "pageName": "Beaumaris-Weather",
        "country": "Australia",
        "countryCode": "au",
        "type": "Davis Pro 2",
        "place": "Beaumaris, Tasmania",
        "img": "davisPro2"
Kindest Regards,
Tony
iatros
Post by iatros » Sat May 27, 2023 7:45 am
Hi all
my site is there, ok, but I moved house now three years ago and the user map is still showing the old place - even though I've updated everything in the main setup.
Not your fault, justinhow, thanks all the same for the excellent idea and the good job!
Cheers !
Language Admin für Deutsch
johnathan
Station model: wh1080
Post by johnathan » Tue Jun 13, 2023 9:29 am
Thank you!
justinhow
Location: Dumfries, Scotland, UK. My site is geo restricted
Post by justinhow » Tue Jun 13, 2023 10:54 am
Unfortunately this appears to be broken at the moment (could be forever...).
If you go to http://www.meteotemplate.com/ and click on the Users tab you will just see php errors:
Warning: Undefined array key "Alt" in /data/web/virtuals/104571/virtual/www/web/users.php on line 17
If and until this is fixed by Jachym my download verification script can not work.
I am not sure when this error started, but the current verified file is from March 2023.
Sorry!
justinhow
Post by justinhow » Tue Jun 13, 2023 11:13 am
Ok - things are not as bad as I had feared because although there are a lot of php errors on the Users part of the meteotemplate websit there are also good records (if you scroll past the errors) and apparently my script can handle that (pleasently suprised) so the user file is now being updated again.
Just to also mention that due to an error on my site (down to a reconfiguration in March) there were no updates to these verified files between March and now. I have now fixed this so it should be updating again.
justinhow
Post by justinhow » Tue Jun 13, 2023 4:00 pm
Just to update here that I have now made this verfied users.txt file available on a shared folder on my onedrive which anyone should be able to get to. See my signature below.
