I moved and built a new ubunto 24.04 vm installed Php
Installed Mysql 5.7 added mysqli and Curl
Used the install from my Florida Meteotemplate Cranberry which was working
I changed the url in Template1/config.php to reflect new time zone, domain name and have left everything else
I created just the scheme in mysql to reflect the database it should connect to also the username and password i have in config.php
I have a phpinfo in the template1 folder which I can connect to and all looks good there
I do not have https cert for it yet but I cant pull up any pages they are always blank using ?errors
Any ideas what I have missed ?
Permisions are 755
I can try a fresh install if that is my only option
What owner, group and permissions are you all using?
Install on new vm cant get past white pages
spd2612
- Station model: Davis Pro 2
- Software: Meteobridge Pro 2
Re: Install on new vm cant get past white pages
If i delete the config.php can i run the install again
It seems to me i have done something in the past to be able to run the intall again
FSC830
Blank like seen in this screenshot (at bottom)?
blank screen
Or like this?
another blank screen
blank screen
Or like this?
spd2612
No blank white screen nothing displayed at all
I have it running off my old VM now and just have 2 domains pointing to it
FSC830
Do you use the modified interactive banner which shows the local rain?
If so, check this post if this may be matches your issue.
spd2612
Well this just got real intresting
I could not get past the white page even config.php so I went back to my vm that was at my old domain which did work
I created a new wesite pointing to the old website but using the new domain basically just another conf file
All worked pointing to both domains but only on my wifi
If i switch my phone or pc to vpn or put my phone on cell neither domin works cant be dns as i am typing in the domain name
Here is a screen shot but i bet you cant get to that domain jonesboroweather.com
spd2612
Well it does appear that my isp is blocking port 80 now but leaving 443 open
I do have a fiber line coming in but may be a couple weeks
This isp sucks
This isp sucks
