Hi everyone, today I decided to install the FIRE DANGER 2.1 block on my site.
But unfortunately when I go to configure the plugin settings, the earthquake block settings appear why???
fireDanger Plugin Not working!
Cavaliere
- Station model: Peet Bros Ultimeter 2100
Cavaliere
Re: fireDanger Block Not working!
Can anyone help me with the fire alert block?
I tried removing and re-installing the block, but nothing changes, when I try to edit the settings for this block, the earthquake block settings appear.
milesb
Re: fireDanger Plugin Not working!
If it is any consultation, I get the same results when I try to edit settings.
MooseAviation
- Software: Meteobridge, WeatherCat
Install the fireDanger plugin and then the block will work properly. I discovered this by examining the code. There are no settings for the firedanger block even though a selection appears on the installed block page. The firedanger block showing settings for earthquake is a programming error.
