updated interactiveGraph block
Update the block to include additional sensors
ver 11.4c
- sensors grouped ( differently )
- added 2 axis graphs
- added option to rename multiple sensors
- added multiple sensors graphs: PP#, SM#, ST#, T#, H#, CO2_#
ver 11.4d
Added an option to handle 'events' ( leave blank if not used )
Currently supported ( may be expanded if needed ):
raining,MM ( shows precipitation when RR>0 in the last MM minutes, if MM=0 uses the data from meteotemplateLive.txt, if MM>0 uses data from database )
windy,SS,MM ( shows wind when wind speed > SS in the last MM minutes, if MM=0 uses the data from meteotemplateLive.txt , if MM>0 uses data from database, SS is expressed in the same unit as saved in database )
windyG,SS,MM ( shows wind when wind gusts > SS in the last MM minutes, if MM=0 uses the data from meteotemplateLive.txt, if MM>0 uses data from database, SS is expressed in the same unit as saved in database )
ver 11.4c
ver 11.4d
- interactiveGraph_11.4d.zip
- (10 KiB) Downloaded 1628 times
- interactiveGraph_11.4c.zip
- (9.54 KiB) Downloaded 1737 times
- meteolopik
- meteolopik
Re: updated interactiveGraph block
T1 (extra temperature sensor 1) is not working for me, not sure if my settings are wrong. I named it T1 as in te database.
Corrected visualization of external temperature and humidity.
- interactiveGraph_11.4a.zip
- (9.52 KiB) Downloaded 1258 times
- meteolopik
- meteolopik
Found another small bug. In extra temp the temperature does not go below 0
Removed 0° minimum for external temperature
- interactiveGraph_11.4b.zip
- (9.54 KiB) Downloaded 1585 times
- meteolopik
- meteolopik
- The dewpoint color in the temperature group stays white eventhough another color is set in the settings.
- Barometric pressure is not loading (pull from database incorrect maybe?
Corrected visualization of pressure sensor and color of dew point
- (9.54 KiB) Downloaded 1263 times
- meteolopik
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
ciao Davide, complimenti per il tuo skill, bravo!
ti propongo una ulteriore modifica, se fattibile:
in caso di precipitazioni in corso, si potrebbe far visualizzare il grafico della pioggia? poi, quando smette di piovere, ritornare al grafico con il parametro impostato di default
(praticamente una opzione che se piove visualizza il grafico precipitazioni, se non piove, quello di default)
grazie
grazie
Added an option to deal with 'events'
Today should be the right day to test it
- (10 KiB) Downloaded 1483 times
- meteoesine
ver 11.4f
Minor update: added the capability to show only a subset of extra sensor.
For example if you want to show only extra sensor T3 and T4 set
( settings are compatible with previous version )
ver 11.4g
Corrected a bug in wind bearing calculation ( no correction should be applied to bearing, but I applied the same correction of wind speed )
Name of Extra Temperature sensors: 3=name3,4=name4ver 11.4g
- interactiveGraph_11.4g.zip
- (10.07 KiB) Downloaded 1263 times
- interactiveGraph_11.4f.zip
- (10.24 KiB) Downloaded 1324 times
linux150
- Station model: WMR968
- Software: SDR -> Weewx -> MT
Thanks for your update.
I´ve a problem with showing UV. UV is on true, but not shown,,,,
I DONT HAVE A SOLAR Sensor, so i didn´t aktivate in main settings.
Now i think, maybe UV is only shown WITH Solar Sensor is activated ?!
Any solution ?
PS: How can i make the bearing graph a little bit smaller?
EDIT: I tried and switched the "Solar Sensor" to true and now uv is shown! But i dont want this settings, because Solar shows allways empty entries in other blocks or actually data...
Maybe i try to edit the php file, will take a look ...
LG
Martin
Any solution ?
LG
Martin
linux150
So i answer myself, i did by try and error, because im an absolutly newbie in programming php (but i learned a lot, installing meteotemplate
So i copied some parts and changed the parameters so now it works ONLY with UV Sensor and NO SOLAR SENSOR for my sensor conditions.
Maybe it helps somebody with same problem ....
LG
Martin
LG
Martin
ver 11.4i
Minor update: added evapotranspiration
- interactiveGraph_11.4i.zip
- (10.95 KiB) Downloaded 1760 times
Laglene
- Station model: Davis pro 2
- Software: Weatherlink
Hello Davide,
Thank you for this interactivegraph block, however a question please
How to change the color of the curves thank you
Didier
Didier
Laglene
Bonsoir Davide,
Désolé, la réponse est dans le nouveau block. je n'avais pas assez exploré votre travail.
Encore merci pour tout ce que vous faites.
Didier
Didier
ver 11.6
- minor update to remove some nasty side effects when customGraph block is installed too
( this update is only needed if you use block customGraph )
ver 11.7
- minor update: added option to show max solar radiation ( calculated ) along measured one
ver 11.7
- interactiveGraph_11.7a.zip
- (11.17 KiB) Downloaded 1051 times
- interactiveGraph_11.6.zip
- (10.91 KiB) Downloaded 1249 times
Gerrit
- Station model: Vantage pro 2 plus
Good day to you,
what a nice adjustments these are, especially the possibility to show graphs of the soil sensors, that was the only thing that kept me with another software package, which I will stop right now.
I do have a small problem, which is also with the original file, that during the loading the program temporarily freezes.
Furthermore, I have the question if there are also adjustments possible to view the history of the ground sensors, I have data from 2018 onwards.
Gerrit
Gerrit
I'm currently working on extending The interactive and the extended graphs.
I've already updated the 'statistics' pages ( but currently didn't post the mod )
Please post a link to your site so I can take a look at the 'freezing issue'
