hi all i'm upgradet from cumulus to weather display but the wind speed an rain gauges are not responding in the template
when i look at the wather display screen its reeds te correct speedin KMh and rain into mm but into the template gauges its stays at 0.0
can anny one help me to solve this please ?
see my meteotemplate at : www.pd3lkn.nl
greetings Eric
Gaugus are not correct
Re: Gaugus are not correct
Check the main setup, adjustments section, the 'Daily precipitation' and 'Wind speed' parameters should be 1 ( or something like that ) but not 0, as these are multiplicative parameters.
I noticed that your graphics are a little bit weird ( for example the temperature one has a lot of 'square wave' noise superimposed )
pd3lkn
- Station model: ws4000
- Software: cumulus
Thanks that was the trick
now the only thing i have to figure out is the wind gauge compass is giving the wrong direction when it is South its pointing to the SW so its a view degrees off
