updated radarEU block ( radarSat24 )
ver 3.2
- added options to configure the 2 maps ( left and right map ), single map is supported too
- added option do define initial map type and timezone
NOTE
I think that this block should be called radarSat24 as it shows maps for Europe And Africa ( currently America, Asia and Oceania not working )
Wondering if may be useful to add a second drop down box to select map type independently for left/right map
NOTE
- radarEU_3.2.zip
- (2.6 KiB) Downloaded 821 times
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Re: updated radarEU block ( radarSat24 )
update completed
thank you davide
thank you davide
djpoppy
- Station model: GW2000 - WS90
Does it still work for you? My radar doesn't load anymore...
Quick and dirty block update:
ver 3.3
- changes due to sat24.com changes
- available only rain radar and satellite maps
- maps are now provided by meteox.com and cover the whole world ( so radarEU is not that appropriate any more )
- rerun the setup as parameters are completely different
- you can still setup one or two maps
To center a map 'on a country', fill in the first parameter ( which is the 2 chars ( always lower case ) code of the country, for example: it for Italy )
To center a map 'on a location', fill in the second parameter ( see https://widgets.meteox.com/en-GB )
Only include one of these two parameters ( if you include both only the 'country code' will be considered ).
ver 3.3
Here is the block ( max 3 attachments per post )
ver 3.4 ( Dec 30, 2023 )
- bug fix ( location on regional/right map )
- corrected dropdown menu position
- added 'default setup' for new installations
- radarEU_3.4.zip
- (3.25 KiB) Downloaded 848 times
- radarEU_3.3.zip
- (2.95 KiB) Downloaded 993 times
giando11
- Station model: Davis pro 2
- Software: Weatherlink
Hi davide, on my site the location doesn't work. Zoom only on Rome. The code that i setting are correct but zoom only to rome
The updated version, on my previous post, should fix the issue you noted
Weerstation Bolsward
thank you
Weerstationwoerden
