I've started working on this block a while back, it is by no means complete ( only standard sensors + UV + L are currently supported )
I like being able to glimpse a whole year data in this way
ver 0.2
- reduced memory usage
new interactiveHeatmap block
- interactiveHeatmap_0.2.zip
- (11.29 KiB) Downloaded 729 times
- interactiveHeatmap_0.1.zip
- (11.32 KiB) Downloaded 738 times
Re: new interactiveHeatmap block
ver0.3
- added extrasensors
- interactiveHeatmap_0.3.zip
- (11.13 KiB) Downloaded 712 times
BlueBear
- Station model: Davis VP2
- Software: WeeWx
Installed but I can't get it to work!
Bottom of page in middle column https://tinyurl.com/bdf2d7x7
Bill
Bill
Meteomeano
- Station model: Davis vantage 2 Plus
- Software: WU
Hi, to me it interferes with interactiveGraph. Removed that works, just go to Edit setting and Save setting at the bottom of the page and it works.
Mario
Mario
Yes, it interferes with the block interactiveGraph ( I didn't notice it as I don't have both blocks shown at the same time, but I should have known, as I derived the block from interactiveGraph : - (
This fix should let both blocks to coexist.
ver 0.4
- renamed variables/functions ( to fix incompatibility with interactiveGraph block )
There is another issue, you may find, if you have the block 'in first layer' of the homepage ( I mean not in a menuBlock at level 2 or subsequent ):
- the heatmap could be called before a needed library is loaded ( this could be fixed with this mod of indexDesktop.php script, it contains also a similar fix for rain block not showing the 'liquid image' )
This mod is not 'strictly' needed, but useful if you find the above issue
ver 0.4
- indexDesktop_rain_heatmap.zip
- (7.16 KiB) Downloaded 742 times
- interactiveHeatmap_0.4.zip
- (10.33 KiB) Downloaded 932 times
