database not updating after switch using ecowitt plugin
spd2612
Software: Meteobridge Pro 2
Post by spd2612 » Sat Aug 17, 2024 11:20 pm
I decided to start a new thread
I had everything working on my old site same linux apache2 server. I created a new site with a different domain and now I can not get my database to update
I am using Ecowitt 35a plugin with a GW1100
My settings are as follows
http://192.168.4.13/scpweather.com/temp ... mypassword {PLUGIN}
scpweather.com/template1/plugins/ecowitt/report/index.php?PASS=mypassword {GW1100}
it is using the same database I used before and is setup and tested in Meteotemplate main setup
I have tried a couple different API.php files and deleted the api cache file
It worked under the old domain name just not under the new one
I tested both urls above with passwords and they both pass
Any help would be greatly appreciated
My API.LOG TXT is showing
starting log: 2024-08-18 00:09:39
INFOS:
Authorized access.
Current date/time: 2024-08-18 00:09:39
api called by http
update U: 1723939779
update SM1: 200
update SM2: 200
update SM3: 200
Begin of common part of api script
Start handling live data
Checking if extra sensors should be logged
Extra sensors data to save in db: TIN, HIN, UV, L, LD, LT, ET, SM1
add live data: D: -112
add live data: DTime: 1723954158
add live data: A: -4
add live data: ATime: 1723954158
calculated D: -112
calculated A: -4
Save meteotemplateLive.txt: {"U":1723939779,"SM1":200,"SM2":200,"SM3":200,"UTime":1723954179,"SM1Time":1723954179,"SM2Time":1723954179,"SM3Time":1723954179,"D":-112,"DTime":1723954179,"A":-4,"ATime":1723954179}
Start data parsing
Parsing date; Server time: 2024-08-18 00:09:39
Validating date: 1723939779 (2024-08-17 20:09:39)
Date is valid; difference with server time is -14400 s
Parsing temperature
Parsing maximum temperature
Parsing minimum temperature
Parsing humidity
Parsing wind speed
Parsing wind gust
Parsing wind direction
Parsing daily cumulative precipitation
Parsing rain rate
Parsing solar radiation
Now parsing extra sensors.
Sensor: indoor temperature not found in API file, skipping...
Sensor: indoor humidity not found in API file, skipping...
Sensor: UV not found in API file, skipping...
Sensor: lightning not found in API file, skipping...
Sensor: lightning distance not found in API file, skipping...
Sensor: lightning time not found in API file, skipping...
Sensor: evapotranspiration not found in API file, skipping...
Sensor soil moisture sensor 1 raw value: 200
Limits for this sensor: 0 to 200
Sensor data within acceptable limits.
Cache file is over 30 minutes old, deleting it.
No cache file found, create empty file.
Parsing pressure
Temperature, humidity or both are not valid and dew point calculation is therefore skipped.
Temperature, humidity, wind speed or their combination are not valid and apparent temperature calculation is therefore skipped.
End time for database update based on timestamp of current data: 2024-08-17 20:09:39
Rounded end time for database update: 2024-08-17 20:10:00
Not yet time to update the db, saving new data to cache/apiCache.txt
Generating log file cache/apiLog.txt
ERRORS:
No temperature data provided.
No max temperature data provided.
No min temperature data provided.
No humidity data provided.
No wind speed data provided.
No wind gust data provided.
No wind direction data provided.
No precipitation data provided.
No rain rate data provided.
No solar radiation data provided.
No pressure data provided.
ending log: 2024-08-18 00:09:39
Davis Pro 2
Meteobridge Pro2
GW 2000
WH57 Lightning Detector
spd2612
Re: database not updating after switch using ecowitt plugin
Post by spd2612 » Sun Aug 18, 2024 9:11 pm
Well I worked around this as I dont see any input here
I am just using forwarding to forward to the virtual server that I want hurricane pub to go to then using hurricane pubs data connection there
Davis Pro 2
Meteobridge Pro2
GW 2000
