"Unauthorised access" for admin user
Brutha
Station model: GW1003
Software: WEEWX
Post by Brutha » Thu Jan 02, 2025 3:41 pm
Hi All,
I haven't really been keeping up with anything to do with my weather website for a while - it's mostly just been working very nicely as I wanted it for the last few years!
But recently I've been having issues with the website address - with newer versions of iOS and MacOS, it's pushing me to the https address instead of http. The http address works fine, but https doesn't.
So, I thought I'd start looking into it - but now I come to login to admin (the lock icon on bottom right of page) it won't let me: I get the message "Unauthorised access". I'm pretty sure I have the right password; if I use anything else I get a different message: "Unauthorized access! Incorrect password specified.".
Can anyone point me in the right direction to start moving forward? I'm on the older version of Meteotemplate (18.0) - this is one thing I also want to address!
Thanks!
Jolumarali
Station model: Vantage Vue
Software: WlIP
Re: "Unauthorised access" for admin user
Post by Jolumarali » Thu Jan 02, 2025 4:42 pm
Find the FTP password in the config.php file ;)
Post by davidefa » Thu Jan 02, 2025 5:25 pm
Also if you enabled the 'Additional Security' option in the main setup you are allowed to access the administrative pages only from the supplied adresses.
If this is the case and you can't login from those addresses anymore, I think you can edit the config.php script near line 152 and:
a) set $enableAdminIP to false ( so you can use any ip to access the admin panel )
or
b) set $adminIPs to the ip you are using now ( you can insert multiple ips separated by commas )
$enableAdminIP = false;
$adminIPs = 'xxx.yyy.zzz.www';
Brutha
Software: WEEWX
Post by Brutha » Thu Jan 02, 2025 6:17 pm
Jolumarali wrote: Thu Jan 02, 2025 4:42 pm Find the FTP password in the config.php file ;)
Thanks - yes, in the meantime I had found a post about that, and checked the config.php - I am indeed using the correct password!
Brutha
Software: WEEWX
davidefa wrote: Thu Jan 02, 2025 5:25 pm Also if you enabled the 'Additional Security' option in the main setup you are allowed to access the administrative pages only from the supplied adresses.
or
Thanks - yes, was already false that one it seems, so does't help unfortunately!
Post by davidefa » Thu Jan 02, 2025 9:12 pm
You can try using this authorize.php script ( extract it in the admin folder it will overwrite the existing script ).
I've only commented out lines 40-42, so you should be able to login after providing the admin password.
Which php version are you using?
authorize.zip
(927 Bytes) Downloaded 520 times
Brutha
Software: WEEWX
Post by Brutha » Fri Jan 03, 2025 4:24 pm
Thanks! Will give that a try once work stop pinging me :)
I'm on 7.4 I believe.
