Hello from Spain. Since yesterday I have a problem. The Steel Series Gauges plugin appears completely empty ... I have tried to remove the plugin completely and reinstall it and it stays the same. When this happens, the block is also completely blank.
The link to the plugin is: http://astrometeopinedas.es/plugins/ste ... /index.php
(It also sometimes takes a long time to load the website but that's another issue ...)
Thank you!
Steel Gauges appears completely empty
Re: Steel Gauges appears completely empty
Several of the scripts (including jQuery) show Connection error, this is a server issue, it returns no data for these Javascript files, which however are fine on your server.
Thanks for your help. What can be the solution? Wait until my hosting fixes it or has nothing to do?
probably, if there is a connection error, there is nothing I can do from my side, the scripts are ok
