additional info to 'bloomSkyLatest.php' image
Post by meteoesine » Sun Oct 22, 2017 1:49 pm
finally my new BS2 is installed and well running :D
I'm coming back with my previous post where I was asking if there is any possibility to add some extra info to the latest image taken from the 'bloomSkyLatest.php' script
My suggestion is to have something like the 'timelapse' ones, maybe with an additional small extension of the image (above or below, transparent or not) reporting a customizable text, date&time and also if possible the current weather conditions as the attached sample image.
thanks to all for any comments
Re: additional info to 'bloomSkyLatest.php' image
Post by Jachym » Sun Oct 22, 2017 1:52 pm
The time and conditions are displayed below in the block/plugin. The image is taken directly from the BS API
Post by meteoesine » Sun Oct 22, 2017 2:05 pm
Hi Jackym,
Yes, I know... but usually the realtime webcam pictures are shared and published just about everywhere, so it is just a little idea to avoid anonimous images.
Post by Jachym » Sun Oct 22, 2017 2:16 pm
Yes, but if you share the images you would use the default BS API where this is not available. And if you use it in MT, then it is shown below the image
