yesterday I released a new plugin for the U.S., showing recent conditions.
Now I created a similar plugin for Canada, but … it is even more sophisticated, showing more parameters and going as far back as 1840, also including possibility to switch map layers and with a sortable table of values. Again, this plugin is using the Leaflet maps API, so no API key is required and data loading should be very fast.
Obviously this was a lot of maps and data so if you find any bug or problem please let me know or just let me know how you like it 🙂
Main features
- monthly summaries for
- Average temperature
- Mean Temperature difference from Normal (1981-2010)
- Highest Monthly Maximum Temperature
- Lowest Monthly Maximum Temperature
- Snowfall
- Percent of Normal (1981-2010) Snowfall
- Total Precipitation
- Percent of Normal (1981-2010) Precipitation
- Snow on the ground at the end of the month
- Number of days with Precipitation 1.0 mm or more
- Degree Days below 18 °C
- Degree Days above 18 °C
- interactive map with many map layers available
- data overview in sortable table
- data from latest to 1840
Enjoy
