steelSeries plugin error: MIME type mismatch (X-Content-Type-Options: nosniff)
Post by davidefa » Sun Jul 18, 2021 10:13 pm
On my new server this plugin shows no gauge ( while the browser error console return this error )
This mod fixes it.
steelSeries_4.0a.zip
(373.5 KiB) Downloaded 936 times
leonrossouw
Re: steelSeries plugin error: MIME type mismatch (X-Content-Type-Options: nosniff)
Post by leonrossouw » Sat Nov 13, 2021 1:16 pm
Thank you...installed the mod...no luck yet.
Link :
http://cannonrocksweather.com/template/indexDesktop.php
Leon
Post by davidefa » Sat Nov 13, 2021 6:00 pm
Sorry, forgot to mention that you have to install this block mod to fix the same issue with the ssGauges block.
( by the way I see your steelSeries plugin is working correctly )
ssGauges_3.1a.zip
(123.13 KiB) Downloaded 1139 times
leonrossouw
Post by leonrossouw » Sun Nov 14, 2021 6:24 am
I have to really thank you...all good now after installing your plugin mod and blockmod :D :D
Leon.
Post by alexvanuxem » Sat Feb 05, 2022 12:29 am
Thank you,
I was busted my ass for hours on this one,
next time check the forum firts..
:D
Post by davidefa » Mon Jul 18, 2022 9:12 pm
v4.1 ( Jul 18, 2022 )
- fixed php 8.0 compatibility issue ( in case selected time format is am/pm )
steelSeries_4.1.zip
(373.59 KiB) Downloaded 852 times
Post by Dehatter » Tue Jul 26, 2022 6:52 pm
Any thoughts on what is making the block fail?
Www.MeckWeather.com
Post by davidefa » Wed Jul 27, 2022 10:11 pm
I'm working on it... ( I need to setup a fully working test site with php 8.1 on my pc as I'm unable to find a free online hosting provider )
Post by davidefa » Sat Jul 30, 2022 4:38 pm
Ok, this should correct a bug that breaks compatibility with php 8.0/8.1 of block ssGauges
ssGauges_3.2.zip
(122.92 KiB) Downloaded 698 times
Post by Dehatter » Thu Aug 04, 2022 4:57 pm
Works perfectly!!
Thank you so very very much. I love my gauges...lol.
leonrossouw
Post by leonrossouw » Tue Aug 09, 2022 6:13 am
I have noticed that the resolution of steelseries gauges is rather poor...it seems better on google chrome browser than for instance safari...see attached example screen shot (both on 4k monitor)
Safari
Safari
Chrome
Chrome
Is there a way to improve this ?
Leon Rossouw.
Post by davidefa » Tue Aug 09, 2022 9:01 pm
I'd say it could be a 'browser effect' ( but I'm not sure and I can't reproduce having no safari at hand ).
Verify if the 'image looks good' at 100% zoom and get worse zooming in, it could be the effect of some antialiasing/optimization/speedup setting of the browser.
bribon
Post by bribon » Sat Oct 08, 2022 9:03 am
Hello!
I have another problem... when entering the plugin I get this error: parsererror: SyntaxError: Unterminated string in JSON at position 1126
What can be the file that gives me this error? I can't find a solution... Thanks!
http://astrometeopinedas.es/plugins/ste ... /index.php
Post by andyk1 » Mon Oct 10, 2022 3:04 am
What ver of Steelseries and whar api version.
Post by davidefa » Mon Oct 10, 2022 1:53 pm
@bribon
I think it is due to the fact that you have no UV/solar sensor.
This mod should fix it ( extract it in the plugins/steelSeries directory ).
ssMeteotemplate.zip
(4.01 KiB) Downloaded 750 times
bribon
Post by bribon » Thu Oct 13, 2022 5:51 am
Fixed up! Thank you very much!!
