steelSeries plugin error: MIME type mismatch (X-Content-Type-Options: nosniff)
On my new server this plugin shows no gauge ( while the browser error console return this error )
This mod fixes it.
This mod fixes it.
- steelSeries_4.0a.zip
- (373.5 KiB) Downloaded 936 times
leonrossouw
Re: steelSeries plugin error: MIME type mismatch (X-Content-Type-Options: nosniff)
Thank you...installed the mod...no luck yet.
Link :
http://cannonrocksweather.com/template/indexDesktop.php
Leon
Link :
Leon
Sorry, forgot to mention that you have to install this block mod to fix the same issue with the ssGauges block.
( by the way I see your steelSeries plugin is working correctly )
- ssGauges_3.1a.zip
- (123.13 KiB) Downloaded 1139 times
leonrossouw
I have to really thank you...all good now after installing your plugin mod and blockmod
Leon.
Leon.
Thank you,
I was busted my ass for hours on this one,
next time check the forum firts..
v4.1 ( Jul 18, 2022 )
- fixed php 8.0 compatibility issue ( in case selected time format is am/pm )
- steelSeries_4.1.zip
- (373.59 KiB) Downloaded 852 times
I'm working on it... ( I need to setup a fully working test site with php 8.1 on my pc as I'm unable to find a free online hosting provider )
Ok, this should correct a bug that breaks compatibility with php 8.0/8.1 of block ssGauges
- ssGauges_3.2.zip
- (122.92 KiB) Downloaded 698 times
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
Works perfectly!!
Thank you so very very much. I love my gauges...lol.
leonrossouw
I have noticed that the resolution of steelseries gauges is rather poor...it seems better on google chrome browser than for instance safari...see attached example screen shot (both on 4k monitor)
Is there a way to improve this ?
Leon Rossouw.
Leon Rossouw.
I'd say it could be a 'browser effect' ( but I'm not sure and I can't reproduce having no safari at hand ).
Verify if the 'image looks good' at 100% zoom and get worse zooming in, it could be the effect of some antialiasing/optimization/speedup setting of the browser.
Hello!
I have another problem... when entering the plugin I get this error: parsererror: SyntaxError: Unterminated string in JSON at position 1126
What can be the file that gives me this error? I can't find a solution... Thanks!
http://astrometeopinedas.es/plugins/ste ... /index.php
- Station model: Ecowitt WS90
What ver of Steelseries and whar api version.
@bribon
I think it is due to the fact that you have no UV/solar sensor.
This mod should fix it ( extract it in the plugins/steelSeries directory ).
- ssMeteotemplate.zip
- (4.01 KiB) Downloaded 750 times
Fixed up! Thank you very much!!
